I took off the RH front sensor (on the drivers wheel), cleaned it up and the reluctor ring on the driveshaft, both of which were quite dirty, popped the cleaned ABS sensor back into place and still the fault remains.
When PP2000 refers to RH does it mean from the perspective of someone sitting in the drivers seat (making RH the drivers side) or someone standing in front of the car facing the bonnet (making it the passengers side)?
Also is there a resistance that i should be looking out for off these sensors?
An important safety point to note about an abs fault is that the abs does not work, the brakes really do lock up and the car will skid leaving the steering useless when it does skid.
