airbag removal tactics
Hi all got to remove a airbag off a scrap car to get the com2000 off. But on mine you put a screw driver through the hole underneath & off it pops lol. But on the scrap car it seams it has 2 screw holes either side of the wheel so are they screws or star screws ????
2.0hdi lx 51 plate 90bhp chassis no.VF38BRHYF81371125
Re: airbag removal tactics
Errr, I think you better check that it is com2000. They'll be torx anyway.
It will be a com2000 but I've gotta get the steering wheel off 1st to remove the com
- rwb
The how to is for the airbag that's held on with a spring, as far as I know if they're not held on with a spring they're not com2000 but I'm keeping an open mind.
Sorry I just presumed all 406's had these com2000 fitted. Thanks for the tip before I attacked it
Aha!
Glad I saved you a job there. Did you see this? viewtopic.php?f=5&t=20855&p=209383&hili ... 00#p209504
yes I've used this guy before he's spot on. it's just there was 2 cars with them & they both felt nice & tight 1 even had cruise control & radio functions. but both had screws holding the airbag & I thought grab them while they were available. oh & £30 each bargain
