I thought my 1.9 was pretty sprightly for it's age and only having 90 horses but the 2.2 is a completely different animal and I love it.
Next the little things on the to-do list so far, all known before buying and a big thanks to Alex for a very thorough and honest test drive;
Remeber that reverse is now by 1st and not by 5th any more!!!!
Thats the biggest issue by far especially if you were the guy on tesco car park last night waiting for me to reverse into a parking space
Air bag light - probably under seat wiring but just need to familiarise myself with the D9 battery removal procedure before tackling that.
Sat Nav cd missing - can it read copies? and if so can someone send me 1 for a few beer tokens?
CD multi changer missing - no biggy but if I spot one cheap I'll pick one up
Get replacement wing prepared for paint and sprayed, same with scratch on drivers door.
Fix dent in sill - metal is dented not holed so I was wondering whether MoT testers would be suspicious of I used filler and assume it had a case of tin worm???
Last niggle and I only noticed last night was the courtesy lights and boot light dont come on.
They work if turned on manually with ignition on and the puddle lights and key in ignition alarm work when the doors are open which presumably rules out bulbs and door/lock switched...thoughts?
