i was told the engine was from a 96 406 sri with 68000(odd) miles on the clock unfortunately the breakers yard from ebay sent me no proof of this.
main parts are
-205 1.9gti cams £25
-Reconditioned 8v SRi head with standard cam never been used (from wigan engine services) - £150
-bottom end - £50 **SOLD**
-nissan s14 t28 turbo bolted to the the 406 sri exhaust manifold ( still requires modification but can explain in more detail if someones interested in a nut shell oil feed needs adapting to the t28 and new compressor clamps as the t28 ones foul the wastegate actuator (due to the bracket for the t28 actuator - £100
- machined flywheel inner lip on the mating surface has been machined off - £30
- other engine parts such as boost pipes, ecu, inlet manifold(metal), inlet manifold (plastic) fuel rail and so on
will get pictures tonight all part will be collection so buy can inspect plus due to weight of most parts
