Sadly not, it's my dad's tubby I'm thinking about here which is completely lacking any kind of turbo actiondogslife wrote:Turbo?
v6?
Planning on getting your money's worth out of the new clutch?
Turbo troubles
Re: Turbo troubles
Re: Turbo troubles
Suspect my wife's turbo also not 100% - car doesnt pull proper. How I reset the ECU?
- Site Admin & Mad Biker!
Re: Turbo troubles
Just disconnect the battery for 10 mins. Make sure you've got the radio code though!Chaz wrote:Suspect my wife's turbo also not 100% - car doesnt pull proper. How I reset the ECU?
Re: Turbo troubles
Ok thanks, we do, thanks.teamster1975 wrote:Just disconnect the battery for 10 mins. Make sure you've got the radio code though!Chaz wrote:Suspect my wife's turbo also not 100% - car doesnt pull proper. How I reset the ECU?
Re: Turbo troubles
Gents the issue described in this thread is exactly what I am experiencing in my 8v Petrol Turbo.
Did this ever get sorted in the end mjb?
Can someone point me to all the turbo hoses to check?
Thnaks
Phil
Thnaks
Phil
Re: Turbo troubles
Nope,the car got scrapped. The air hose to the turbo wastegate is attached to a valve at the top of the engine bay on the left behind the ECU box. The valve has 3 small hoses and an electrical pug coming off and is a good starting point
Re: Turbo troubles
So I had a look at some of the hoses and found a split in the hose which comes from the airfilter box. I have circled it on the following picture in red. From the diagram I can see this is part of the vacuum system as in some pics I can see a BOV connected to the other end.
I guess the question is would a large split in this hose cause no boost at all? It seems very possible looking at the other pipes connected.
Re: Turbo troubles
So new Solenoid ordered which fixed one issue on the vaccum but the turbo is seized solid. Decisions Decisions. Do I scrap the car as it's pretty much BER or do I replace with a recon unit?
