Very late Turbo boost
oldcol
Post by oldcol »
Hi. My 02 plate 406hdi110 estate has suddenly developed a niggling fault. Now i have to say that as nearly all my running is on lightly trafficked rural roads the problem is actually not a 'Problem' as such. However, until a couple of weeks back the car was running fine and in fact it still runs fine, BUT it has developed a strange, to me, fault.
The turbo is not coming on stream until over 3000rpm. A local mechanic did a diagnostic check and the only thing that came up was Crankshaft sensor and Camshaft sensor not synchronised. He put 2 new sensors in but the same fault code comes up and the turbo still does not come in until 3000rpm. Have any of you had this problem and if so how was it resolved ?
Thank you.
Bailes1992
Re: Very late Turbo boost
Post by Bailes1992 »
Sounds like the timing had jumped a tooth or two!
That was my first thought too. It would be sensible to at least check the timing.
And change the timing belt, tensioners etc. if it has...
Contigo
Post by Contigo »
trem1
Post by trem1 »
Contigo wrote:MAF sensor.
Watch this...
http://www.youtube.com/watch?v=tT8yHXJCjJI
one of our very own farmers videos
oldcol
Post by oldcol »
Problem Solved !
Big, big, big thanks to Contigo ! The problem was indeed the MAF sensor. Went around to a mates house and we spent about 10 minutes or so removing the MAF sensor from his 406hdi110 saloon and fitting it to my estate ~ instant fix. Turbo coming in just when it should again. Spent 32 quid for a new aftermarket one from a reputable motor factors, 2yr warranty, and a big smile on my face, the old girl is back to her perky self. The strange thing is that a 1600 quid diagnostic test unit did not pick the fault up.
A thank you also to my mate Eddy for the brief loan of his sensor .
nutski
Post by nutski »
Diagnostic kit will not show a problem with the MAF unless it is physically broken, if it has become dirty it can't read the airflow so in effect sends back false readings
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
jonsowman
Post by jonsowman »
Agreed, you'll only get a MAF fault if the sensor is disconnected or short circuited to either supply rail. Glad it's fixed though, well done :cheesy:
dirtydirtydiesel
Post by dirtydirtydiesel »
oldcol wrote:Problem Solved !
:shock: £1600.00 :shock:
You must be mistaken or mad thats probably the value of your car unless it's in excellent condition & very low millage / one owner.
All the same glad you got it sorted 8)
nutski wrote:Diagnostic kit will not show a problem with the MAF unless it is physically broken, if it has become dirty it can't read the airflow so in effect sends back false readings
Did you keep the old MAF? You can clean it up a bit with brake cleaner, just be careful of the thin wire bits. Give it a go and if it works again it'll make a good spare.
Quinny
Post by Quinny »
Or use this:
http://www.maplin.co.uk/switch-cleaner-27515
It's what we radio hams use on sensitive electrical circuits.
1999 V 406 HDi sold in 2011
2002 02 plate 406 HDi 110 bought 16/11/2013
jonsowman
Post by jonsowman »
Quinny wrote:Or use this:
Off topic, but M0JSN 8)
Quinny
Post by Quinny »
G8FSO.
dirtydirtydiesel
G8FSO.
W.T.F :cheesy:
