cold feet
Re: cold feet
I think they all do that - both of mine have.
If you look, the heater outlets are just in front of the ashtray, at the bottom of the console. Don't think there are any further forward than that.
When I had the console out of this one, I found the duct between these outlets and the heater adrift. Managed to get it nearer ro properly fitted, but it didn't make much difference......
Re: cold feet
I agree.... With Miss Pug I never really took notice but for some reason this car just feels so much colder (probably the leather one is sitting on now).Doggy wrote:I think they all do that - both of mine have.
With the 205s their heater vents were above the pedals so your feet got blasted with hot air, was shocked to discover only a couple of weeks back that the heat only blows from the rear of the centre console... so essentially, unless your foot is always on the clutch pedal (or the rest) you won't feel much of the benefit, you're always going to have a cold right foot.... and I could easily say another reason to hate my 'new' car but I think the boys have learned my moans are all heading in one direction.........
Miss Pug 2001 - 2023.
Re: cold feet
Maybe it's a right-hooker thing but I've never noticed a lack of heat to my feet (hey, that rhymes
Sure there are:Doggy wrote:If you look, the heater outlets are just in front of the ashtray, at the bottom of the console. Don't think there are any further forward than that.
I can only suggest you all do a bit of grovelling about and make sure there is air coming out of these vents, that they're not blocked and the flap is reaching its lowest position. Like Doggy, on my D8 I found the chimpanzee that had the floor console out last hadn't bothered to put the ducts back together, err, at all, so most of the air was just warming up the bottom of the floor console...VENTILATION
1 - Windscreen de-icing or demisting vents.
2 - Front window de-icing or demisting vents.
3 - Side vents.
4 - Central vents.
5 - Air outlet to the front passengers' feet.
6 - Air outlet to the rear passengers' feet.
Recommendations for use
Position the air flow control at a level which allows adequate air circulation inside your vehicle.
Select the air distribution which best suits your requirements and the climatic conditions.
Select a temperature setting and only alter it gradually for your comfort.
For an even air distribution, make sure that you do not block the air inlet grille at the base of the windscreen, the vents, the
air passages under the front seats and the air extractor in the boot.
Re: cold feet
My 406 had fantastic footwell heating, that's one of the things I liked about it, weirdly the 406 was the only Climate Control I've seen where the user decides on the airflow direction, I used to set mine to
and
if I remember, i.e. Footwell and Windshield and then the centre vents could be controlled by their own dampers manually.
Re: cold feet
Yep I use the same setting I remember seeing the vents while fondling about under the dash for something last year....Welly wrote:My 406 had fantastic footwell heating, that's one of the things I liked about it, weirdly the 406 was the only Climate Control I've seen where the user decides on the airflow direction, I used to set mine toand
Re: cold feet
Agree with Doggy, mt D8 estate blows on my feet with all the force of an asthmatic ant. I've had it 5 years now and as far as I can remember it's always been rubbish.
MacWomble.
Silver 406 GLX Estate, 1998 2.1 12 valve. 302,000 miles and counting.
White Renault 5 GT Turbo, 1991 58,000 miles, all original, mint condition.
Re: cold feet
My d8 estate also is very wanting in the feet warming department even with other vents closed
- Captain Jack
Re: cold feet
Ditto on both my 406s. 407 on the other hand is nice and warm there!
Re: cold feet
Petrol engines are a lot less efficient than diesels, so generate a lot more heat. I've not yet driven a diesel that can give me much more than lukewarm air by the time I've gotten to work, yet every petrol I've had could give warm air about half way and be fully up to temperature at about 3/4 of the waySonia406 wrote:I agree.... With Miss Pug I never really took notice but for some reason this car just feels so much colder (probably the leather one is sitting on now).
Do any 406s have auxiliary heaters on the water line to the cabin?
Re: cold feet
Er yes, I think, on early HDis there are heater resistors and on later ones they have that water jacket around the egr pipe.
Re: cold feet
Yeah.. know what you mean... By the time I get to school I end up leaving it running to get a bit of heat in there... which then makes it less fuel efficientmjb wrote:Petrol engines are a lot less efficient than diesels, so generate a lot more heat. I've not yet driven a diesel that can give me much more than lukewarm air by the time I've gotten to work, yet every petrol I've had could give warm air about half way and be fully up to temperature at about 3/4 of the waySonia406 wrote:I agree.... With Miss Pug I never really took notice but for some reason this car just feels so much colder (probably the leather one is sitting on now).
Miss Pug kept us all nice and warm
Re: cold feet
Just as an addition to this: I've just been running me Pug (it's tucked up in the shed for winter
) and I was cycling everything I could think of when I remembered this thread. Putting the heat and fan to max I can feel nice warm air coming out of all 4 floor vents but I did notice that the sound deadening in the driver's and passenger's footwells is starting to sag and if they carry on I can well imagine warm air being scooped pointlessly behind the dash, rather than down at our 'ickle cold tootsies.
