New tyres
Re: New tyres
Really? Maybe I'll set what else is there then.....
Will they be any good on the back wheels....?
jonsowman
Re: New tyres
Post by jonsowman »
They're probably better on the front to be honest, more weight over them.
Had a pair on the rear of my 2.1 and they were really bad in the wet. Had the back step out a couple of times around roundabouts and I wasn't pushing it in the slightest! Swapped them for Bridgestone Turanzas when they wore out, hugely better. The fronts were Conti PC5s which were also excellent. The Coupe has Pirelli P7s on the rear which are fine, it's just the P6000s which seem to be questionable.
You might have more luck with them :)
gumby6371
Re: New tyres
Post by gumby6371 »
Not sure of the location but there is a set of starfish alloys on the bay of e for £165 with 5 good budget tyres on. They are bigger than yours but at less than £35 a wheel worth a look.
2003 2.2 HDI SE
Re: New tyres
P6000's used to be called 'ditchfinders' no-one had a good word to say about them, I had them on a 3-series and they were no good in the Wet or Dry :?
I'd try and get some Part Warn Michelins or Eagle NCT5's if poss.
@tremmy in your situation then get part-worns, I don't see the problem. Like we've said before; if you buy a second hand car you don't change all the tyres for new do you? (Bailes might :P ).
jonsowman
Re: New tyres
Post by jonsowman »
Welly wrote:P6000's used to be called 'ditchfinders' no-one had a good word to say about them, I had them on a 3-series and they were no good in the Wet or Dry :?
Glad it wasn't just me :cheesy:
trem1
Re: New tyres
Post by trem1 »
Agreed Welly, and infact there on, i was just curious as to what Sam would do in this situation being a part-worn hater.
Re: New tyres
Sell the car and buy one with newer tyres? :?
I hope you checked the date codes!
Re: New tyres
trading standards don't seem to botherd about p/w tyres..
Quote from Ts,. Condition
Part-worn tyres, whether deflated or inflated to the highest operating pressure at which they are designed to operate, must not have:
•any cut over 25mm or 10% of the section width of the tyre (whichever is the greater) on the outside of the tyre, deep enough to reach the ply or cord
•any internal or external lump, bulge or tear caused by separation or partial failure of its structure
•any ply or cord exposed internally or externally
•any penetration damage that has not been repaired
In addition, the grooves of the original tread pattern of the tyre must be at least 2mm deep across the full breadth of the tread and around the entire outer circumference of the tyre.
trem1
Re: New tyres
Post by trem1 »
steve_earwig wrote:Sell the car and buy one with newer tyres? :?
Bugger :oops: Actually no i didnt check but because of my hernia my eldest son babysits me when i go for these things at the moment and he did.He fully inspected both tyres for tread depth,any signs of sidewall damage etc etc. He's way more picky than me when it comes to tyres, I put it down to riding motorbikes, makes you respect them abit more
Re: New tyres
I remember that 3-series we had with the P6000's I went to a Part-Worn place and said "I want to look at the tyres closely".......I got took across the road to the Warehouse Unit.....the shutter was opened and the bloke said "there you go, knock yourself out".....I spent *ages* inspecting them and finally got a really nice pair of Michelin Pilots for beer money.
Re: New tyres
Anybody found anything they do swear by, (instead of at)?
My 'new' Dunlops seem to have mislaid their tread, with remarkable consistency, across the whole width of all 4 of the blighters*.
Still got the receipt in the glovebox, let's see......16/03/2013. :shock:
* testifies to the skill and attention to detail shown by a certain hunter-equiped tyre emporium in welly's part of the world, (You're not gonna be as anal as that guy with the volvo with shiney suspension, are you)? *
Bailes1992
Re: New tyres
Post by Bailes1992 »
trem1 wrote: So Sam what's your suggestion in my case.
Dad to 4 kids all pretty much grown but still expect presents all the same, Granda to 5 grandkids, again expecting presents, its the 12 December and ive just gotten an unrepairable puncture to a front tyre.Both fronts are down to 3mm so were getting changed soon but i can get a pair of Bridgestones(Part-worn for £30 each fitted) or a pair of the cheapest tyres locally no idea of make etc etc at £60 each, bearing in mind i'm on the sick from work at the moment only on SSP so i'm about £300 a week short on money.
So should i go part-worn on a known tyre or new on a unknown tyre ??
I personally would do my research on tyre review websites and get the best budget I could afford new! When my tyres get down to around 2mm I work out my budget and start shopping for tyres. By the time I've made a decision they're on their last legs! :lol:
At the end of the day regardless of whether or not you can see any damage to a tyre you have no idea what's going on inside the rubber!
You have no idea if they've been up and down kerbs at 30mph, if they've come off a crashed car or if they've hit a pothole at speed!
Welly wrote: @tremmy in your situation then get part-worns, I don't see the problem. Like we've said before; if you buy a second hand car you don't change all the tyres for new do you? (Bailes might :P ).
Difference is when you buy a wheel with a tyre or a car with tyres you can look at the wheels and make an assumption about the condition tyres by looking at damage to the wheel!
lozz wrote:trading standards don't seem to botherd about p/w tyres..
They also have to have 'part worn' stamped on them in white! I've never seen ONE part worn tyre with the correct stamp!
If they regulated the sale of part worn tyres I might consider using them, or even consider them 'safe'.
The fact that tyres can be taken off a smashed up car / scraped car and sold on again with no real checks totally scares the absolute sh*t out of me! :?
I've seen on two seperate occasions part worn tyres blowing out within weeks of them being fitted on mechanically sound cars bought from reputable tyre shops!
It's disgusting that trading standards lets this go on yet there are specific rules out there that are supposed to govern the sales of part worn tyres. Yet nothing ever gets enforced!
You've goto ask yourself. Why was this tyre removed from a car originally? :?
Worth a read!
http://www.autoexpress.co.uk/car-news/3 ... re-scandal
Doggy wrote:Anybody found anything they do swear by, (instead of at)?
Pirelli P7 Cinturato! Came as standard on the Beemer. The rears didn't need replacing till 38,000miles and the front still had 3mm left to go at 45,000miles! The only reason the fronts were replaced as they were wearing heavilly on the outer edge! Unfortunatley it's a trate of the F30!
The new Goodyear Eagle NCT 5's aren't wearing half as well!
Re: New tyres
They don't just throw tyres on.
they are checked 1st.
part worn tyres are available for a number of reason's. theres plenty of people out there with 'Deep pockets that will change afull set of tyres rather than just
1 or two, ive seen people do it, they don't even ask for the tyres back,
some tyres come from abroad too where its more stricter,
Not everyone has Deep pockets, so part worn tyres are better than driving around on the limit until they can save up for some,
if partworn tyres where bad they wouid be Banned, just like Re-molds where,
trufflehunt
Re: New tyres
Post by trufflehunt »
I've bought part-worns from the same dealer , for several cars, over the last 7 years.
They only sell part-worns. Never had a problem with any of their tyres.
They do a good trade, because they're fast, efficient and good value for money.
On the 406, when I bought the car, it had Roadstones on it, a cheapish make I think.
As mentioned, it now has 3 out of 4 Michelin Energy Savers on. Car feels smoother,
and more sure-footed. And the Michelins will last longer.
When I had them fitted, the dealer offered a choice of the Michelins, Uniroyales, couple of
Pirellis and sundry budgets. I'd have been quite happy to have the Uniroyals, just went for the Michelins.
Why would I want to spend £150 to £200 for a set of no-name budget tyres whose technology is light-years
behind the best.
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
trem1
Re: New tyres
Post by trem1 »
lozz wrote: if partworn tyres where bad they wouid be Banned, just like Re-molds where,
Now there's another story.....Remoulds, wouldnt touch them no matter what, cheapest tyre no matter what has to be better than a remould so many horror stories with those.
Sam you missed my point a bit, i had an unrepairable puncture so needed tyre/s the next day so no real time to do research and 2 weeks before xmas they had to be cheapest possible
