Another Dpf Question
OllieNZ
Post by OllieNZ »
Hi All,
I'm looking into removing the dpf on my 307 1.6 110hdi and as I understand it its an ecu out job as flashing it via the obd is not reccomended. The way I understand the dpf system works is there are sensors before and after the filter and once the pressure differential builds the car runs a regen cycle. Now the way I see it I can remove the filter without causing any issues it's just that the rest of the system will continue to function as normal (without running regens as there will be no pressure differential) until I get a software removal carried out :supafrisk: .
Anyone care to point out any flaws in this plan?
gumby6371
Re: Another Dpf Question
Post by gumby6371 »
My other half has the same car as you and I believe there must be a certain level of pressure differential between the sensors due to the filter element, so simply removing the filter would cause an error and probably limp mode due to it falling outside the operating range.
Unless you can fool the 2 sensors into believing there is a difference in the correct range you'll just have to wait until it can be remapped properly.
2003 2.2 HDI SE
OllieNZ
Post by OllieNZ »
gumby6371 wrote:My other half has the same car as you and I believe there must be a certain level of pressure differential between the sensors due to the filter element, so simply removing the filter would cause an error and probably limp mode due to it falling outside the operating range.
:x
Have you had any joy sorting your mrs car out?
Not only that, but they do regens based purely on distance, as well as differential pressure.
Is that how it works out the 'blockage' - by the two pressure sensors?
Yes, (but it's a single differential pressure sensor, which measures the pressure difference each side of the cat/dpf assembly).
gumby6371
Post by gumby6371 »
I've been jet washing the DPF every couple of months as a temporary fix until I can afford a proper remap for it.
As you say the ecu needs to be bench flashed so not a DIY job unfortunately.
2003 2.2 HDI SE
OllieNZ
Post by OllieNZ »
gumby6371 wrote:I've been jet washing the DPF every couple of months as a temporary fix until I can afford a proper remap for it.
How long does it take you to remove/refit and do you take the whole assy out or just undo the clamp and drop the bottom half out?
Just been in contact with hdi tuning £150 for remap/dpf delete and you can post the ecu to him if that helps
