These holes might be small like mentioned above but i doubt you'd need the engine to take in that much water to cause problems, also think of gravity flow it maybe going in a northern direction but once a steady stream is formed the water will continue to fill the engine until there's no water to suck (even with engine off) or dead as the case may be.munkymanmatt wrote:Well I was thinking that too but if you stick your hand in front of the air intake with the engine running you might change your mind, the engine really does draw an enormous amount of air in over the course of a few seconds when throttle is applied, so while the holes might appear too small to allow enough water in, if they were submerged for a few seconds (or longer when driving through fords and the like) you could end up with a catastrophic amount of water in the engine.Ares wrote:I dont think those 3 holes are the main problem....they appear to small to pull something serious inside.
Considering how big the air intake hole is when compare to those 3 tiny holes it just seems impossible that trough there water gets in.
I am more fan of that theory that simply waters builds up between bumper and that plastic wheel arch and combine with low air intake system,creates disaster.
Steve by cool I meant not 80C plus![]()
Indeed, a water pump mightn't be as good (unless it was combustion powered maybe) but I have no access at all to a wet vac.
A 306 retrofit sounds good but I'm the same. Local breakers are useless and a ripoff
All this talk of sucking and blowing I'm off back to bed.
