Radio Stalk not function after replace MFD
bl4ckclio
Post by bl4ckclio »
hello all
I notice my radio stalk stop function after I replace faulty MFD.
and I have thrown the faulty one :(
I think all D9 MFD are same...but they are not.
anyone know what should I do?can PP2000 restore my radio stalk function?
it's 2004 D9 full mux.
thank you.
Re: Radio Stalk not function after replace MFD
I found when changing from a Type b (two button) screen to the type c (sat nav) screen that the stalks did not respond and the pp2000 was needed to change the settings, but i don't think if you replace a B screen with another B screen that it would cause such an issue
bl4ckclio
Post by bl4ckclio »
FarmerPug wrote:I found when changing from a Type b (two button) screen to the type c (sat nav) screen that the stalks did not respond and the pp2000 was needed to change the settings, but i don't think if you replace a B screen with another B screen that it would cause such an issue
the problem is from type B (2004 full mux) to B (2003 semi mux)
maybe this link similiar with my problem:
http://www.peugeotcentral.co.uk/ftopic-6412.html
so PP2000 can do for new fitted MFD, right?
They are fully multiplexed after 2002 i believe, I've had screens in between pre multiplexed and multiplexed cars without any issues but perhaps pp2000 may just configure the settings correctly.
bl4ckclio
Post by bl4ckclio »
allright
I will try configuration with PP2000
of course after I finish struggling installing PP2000.
got 3 set chinesse lexia 3, nothing working at all. don't know what's the problem.
have tried a lot of manner, fresh copy winXP, different NB, different car, different software :x :x
bl4ckclio
Post by bl4ckclio »
bump....
any idea how to config after replacing MFD/radio stalk through PP2000?
thanks.
V6Exec
Post by V6Exec »
very simple - go into replacement parts and configre it from there
406 Coupe S HDi
PP2000 clone interface
bl4ckclio
Post by bl4ckclio »
V6Exec wrote:very simple - go into replacement parts and configre it from there
I have tried configure it.
when I go to MFD menu -> next -> it list MFD part numbers and asked am I on that list -> ok -> no cummunication ?
go to control under steering wheel I see that "Radio Stalk*" there is " * "
but when I press volume +, it state active, release then deactive....so that with others
on global test, I have message MFD -> no +ve permanent live on display.
is it dodgy connector on BSI?
what kind of connector is 16NR base on haynes?
V6Exec
Post by V6Exec »
Make sure you are in the replacement parts section.
Look for an option for radio controls by wire or by van bus - select wire for the thin stalk an van forthe thick stalk
406 Coupe S HDi
bl4ckclio
Post by bl4ckclio »
V6Exec wrote:Make sure you are in the replacement parts section.
yes, I have choosen the van bus
next,
I go to test by ECU -> Radio -> fault reading -> "Remote intermittent fault. No Communication with multifunction screen"
because my car is full mux, hard to trace where is the problem.
I see on VAN bus diagram, several wire go-leave to interconnection.
V6Exec
Post by V6Exec »
Clear all faults and see if they remain.
If they do take the screen out again and make sure all cables are tight.
406 Coupe S HDi
markw
Post by markw »
bl4ckclio wrote:what kind of connector is 16NR base on haynes?
16NR just means it's a 16 way connector and it's black (French...Noir)
