Now that's an idea!Welly wrote:Wiggy - don't you have any expansion vessels to take up the expanded warty pressure?
Yes, you just can't really buy non-condensing boilers, just condensing ones, aka time bombsBailes1992 wrote:Can you still buy er... Non Combi boilers?
(you can't fit a Power Shower to a Combi Boiler)Welly wrote:Wiggy - don't you have any expansion vessels to take up the expanded warty pressure?
Bailes - you can't fit a Power Shower to a Combi Boiler, the shower pump will try to drag water through the Combi at a rate of knots and the boiler won't keep up, and the water pressure will also be too high (feeding the shower pump). Power Showers are designed to draw water from a storage vessel at equal-ish pressures, I have the showers with a built-in pump (look like an electric wall mounted shower) and they are very good, if a tad noisy, but they do need tank-fed Cold and via the Tank fed Hot.
Daft thing is that in 99% of houses in the UK a Condensing Boiler cannot function as it was designed to and is therefore much less efficient than you'd expect. Condensing boilers need low return water temps to take advantage of the heat absorption from the flue gasses, trouble is the radiators are sized for higher flow and return temps of 82 and 71deg C, if you run low temperatures then firstly you'd struggle to generate hot water and secondly the radiator heat output won't be enough. The condensing boiler is only working 'properly' during initial warm up through 40 to 60 deg's, after that it's just a 'boiler'Doggy wrote:Yes, you just can't really buy non-condensing boilers, just condensing ones, aka time bombsBailes1992 wrote:Can you still buy er... Non Combi boilers?
Figures.Welly wrote:Daft thing is that in 99% of houses in the UK a Condensing Boiler cannot function as it was designed to and is therefore much less efficient than you'd expect. Condensing boilers need low return water temps to take advantage of the heat absorption from the flue gasses, trouble is the radiators are sized for higher flow and return temps of 82 and 71deg C, if you run low temperatures then firstly you'd struggle to generate hot water and secondly the radiator heat output won't be enough. The condensing boiler is only working 'properly' during initial warm up through 40 to 60 deg's, after that it's just a 'boiler'![]()
The best way to take advantage of a condensing boiler is to have underfloor heating running at about 45 deg and then a separate system of generating hot water.
Depends on what boiler it is?Welly wrote:Daft thing is that in 99% of houses in the UK a Condensing Boiler cannot function as it was designed to and is therefore much less efficient than you'd expect. Condensing boilers need low return water temps to take advantage of the heat absorption from the flue gasses, trouble is the radiators are sized for higher flow and return temps of 82 and 71deg C, if you run low temperatures then firstly you'd struggle to generate hot water and secondly the radiator heat output won't be enough. The condensing boiler is only working 'properly' during initial warm up through 40 to 60 deg's, after that it's just a 'boiler'Doggy wrote:Yes, you just can't really buy non-condensing boilers, just condensing ones, aka time bombsBailes1992 wrote:Can you still buy er... Non Combi boilers?![]()
