The use of front fog lights
Re: The use of front fog lights
I think the rot set in with the Mk2 Mondeo.....
Just to show how things have changed, on a 1983 Fiat Strada I once suffered briefly, the rear fog went off if you put the headlights on main beam.
With 1960's Jaguar MkII and S-types, the lighting selector switch only let you choose Headlights OR Foglights
....and they call it progress. :roll:
trem1 wrote:Also on the Astra i had last year the dashboard lights were on as well as the DRL's so it was quite easy to forget to turn your lights on
Hope I never have to drive one of those then, the instrument cluster getting hard to see is the cue I use to put the sidelights on (headlamps go on when i'll be able to see 'em in the road in front...)
Doggy wrote:I think the rot set in with the Mk2 Mondeo.....
On my 63 plate lorry the rear fogs only work with the headlights on.......
But I agree with you all on these new cars, the silly lights on the front does make Honda Civic drivers oblivious to the dark and the possibility of a rear end shunt ( ooer.. :supafrisk: )
I wonder if the main stealers can over-ride these so the lights are only on when its dark, like normal cars..
On a brighter note, the fog probably helped me arrive at work with my trip reading over 50 mpg for the first time ever. :cheesy:
Filled up the night before, 66.3 litres for 700 miles = 48 mpg on the last tankful.
Maybe, I'm losing my touch? :?
