Rear fog lights
Rear fog lights
As if to cause confusion with the "front fog lights" thread... :cheesy: :lol:
Someone on here was recently asking about why only one of the rear fog lights works on the 406. The answer is that you are only required to have 1 rear fog by law, so why have 2 "spaces" in the clusters? It's just untidy!
This inspired me to do a bit of fiddling on the weekend. Got the panel off the inside of the tailgate and noted that the wiring to both clusters looked exactly the same, so I popped the near side cluster out and took a look. Sure enough there's a vacant bulb holder there. Fitted a bulb, plugged it back in (just hanging from the wires under the tailgate and switched the fogs on, and yay, two fogs!!
Nice enough, I'll put it back together then. Oh no, it ain't that easy, they've only gone and made the hole in the back of the cluster undersized on purpose, so that if you fit a bulb in the fog light holder, you cant get the back plate back onto the cluster. Not about to be beaten by such an obvious pre-planned attempt by the viscious bastards at peugeot to spoil my afternoon, I got the dremmel out and butchered the fekkin thing!!!!
So yay, two fogs!
Blue406
406 Gimp
Post by Blue406 »
LOL
You continue to provide excellent comic relief in your writings here Dai....
Laughed my ass off to this.
I just know I'll be ripping my 6 apart tomorrow to check if I can do the same now.
Nice one. I still have to get my front lights to work... grrrr
Good work there Dai, good work. 8)
Weird isn't it. Peugeot scank you for one bulb just because you don't have to have two fogs in the UK. You will probably find it costs them more to block off the hole (or indeed a differnet cluster?) than it would cost just to give you the bulb :roll:
Benner
Post by Benner »
Yep that sounds like Peugeot to me! :cheesy:
I had looked at that on my estate before and realised the same thing (before taking the cluster out though :P ). Think I may take the dremmel to mine too now :)
mjb wrote:Think I may take the dremmel to mine too now :)
I had a little "milling" bit with my dremmel, was suprised how well it cut and how easy it was to make a reasonable circle :lol: :cheesy:
Depends on the material - it doesn't like going through 1.5mm steel PC cases :(
The same bit did a damn fine job of digging the broken end of a speedo cable (ally) out of the gearbox of my suzuki though :lol: 8) :cheesy:
Yeah, they eat soft metals for breakfast :D Wonderful things, you can use 'em to chew straight through solid aluminium just on the weight of the dremmel :D
