Interior fan resistor
Hey all my interior is stuck on full blast been told it's the fan resistor?
Any one got one for sale
(02) 406 2.0 HDi GTX Estate AUTO AC+SN in Delft Blue aka Rhodes Blue
Re: Interior fan resistor
Part 6441L2 I imagine. I replaced mine with an eBay one, has been fine:
http://www.ebay.co.uk/itm/Heater-Blower ... 1123501788
What's the best way to check is it just to rip it out?
Also the ac doesn't kick in either even.though it is displayed. Is that the resistor pack 2
No easy way to check it really, but "fan always on full" is this unit failing in all cases I've seen (including mine).
I'm not sure on the A/C question - I'd say unlikely to be related (guessing) but you'll soon find out when you replace the resistor
Am I oo to drive with it unplugged
Hi, if you can reach the resistor to unplug it, then you may as well give the wires a wiggle with the engine running to see if the fan stops ( providing it is set to 'off' )
The eBay ones are a bit 'hit and miss' regarding quality, but mine has been fine for 2 years now.
This shouldn't affect the A/C, there will be another reason why it doesn't cut in.
Because I can press all the buttons and they all work but have no effect. Only the rear demist does anything. This car is on its last warning
All the buttons?dave406 wrote:Because I can press all the buttons and they all work but have no effect. Only the rear demist does anything. This car is on its last warning
The windscreen one needs the fan to be working to clear the screen - does it light up?
The recirculate button probably works but the little motor broken of the flap is stuck....
If the new resistor won't fix the fan then maybe a new heater control panel may do it, I can send you my fully working resistor and control panel from my donor car for a reasonable fee.....
It lights up but can't feel any difference. Auto has no effect eitherGingerMagic wrote:All the buttons?dave406 wrote:Because I can press all the buttons and they all work but have no effect. Only the rear demist does anything. This car is on its last warning
The recirculate button probably works but the little motor broken of the flap is stuck....![]()
What isbyour fee sir feel free to pm me. Ps were you based? As I'm driving a lot of the county this week
PM sent.
