Hey guys,
Ive been browsing my pug parts CD and noticed that the MkII 406 turbo diesels (HDis) come with a narrow vertical intercooler. is there anyway one of these could be fitted to a MkI to avoid heat issues or did peugeot change the radiator design too much between releases. i would guess that the radiator and air con would be different but I cant find any difference on the cd. Anyone help?
intercooler swap
intercooler swap
406 Coupe 3.0 V6 SE
406 Turbo Executive - no idea where it is tho...
- jameslxdt
what engine in the mk1 406 would you be fitting it too?
- jameslxdt
its already got an intercooler, a much bigger one that was shared with the 1.9 and 2.1 td, why go to all that effort to fit a crappy HDi intercooler when you could fit an aftermarket one thats much bigger with better results
- jameslxdt
well its a nightmare to get the intercooler out without removing the rad, and the HDi one is so small, you'd also need different pipework, like i said, your better off getting a much bigger aftermarket one
