Cruise control
Ady1985
2.2 16v
Cruise control
Post by Ady1985 »
2000 plate estate, got cruise control stalk, plugged into 5 pin plug on steering control, took switches off clutch and brake and live tested them and they are working fine but pp2000 registered that brake switch is permanent active, any ideas, only switch I don't have is the on off switch that goes next to diagnosis port.
Re: Cruise control
Did you push the switch in too far?
It needs to be the same distance away from the pedal as the other one, or a tiny bit further out maybe....
Ady1985
2.2 16v
Re: Cruise control
Post by Ady1985 »
Pressed in with finger whilst plugged in, still not having any of it, always saying active, adjusted them, tested switches off car and also stripped and checked internals
Rolebama
Re: Cruise control
Post by Rolebama »
I'd do a continuity check across the brake pedal switch in situ.
1998 2.1 GLX TD
Ady1985
2.2 16v
Re: Cruise control
Post by Ady1985 »
Ordered a continuity tester and ordered a new brake pedal switch, should have both tomorrow, I'll fit new switch and it seems I'll need 1 of these testers as a lot of things need testing and will come in handy in my french collection lol
Ady1985
2.2 16v
Re: Cruise control
Post by Ady1985 »
Done test and even fitted new switch, still showing active on pp2000 even with brake pedal pressed and depressed and switch unplugged, got me bamboozled now.
Re: Cruise control
Oh, I just remembered. I did a quick diagnostic for James a while ago to pinpoint his ABS fault, and his Cruise Control was active too - even though he had no stalk, no brake switch or anything, in fact PP2000 thought his car was an auto..??
Ady1985
2.2 16v
Re: Cruise control
Post by Ady1985 »
Mmmmm abs fault rings a bell on my pp2000
Liliflower
1.6 8v
Re: Cruise control
Post by Liliflower »
