Wanted. 406 2.2 HDI Coupe exhaust rear box
Longshot here but I have bought a 406 2.2 HDI coupe and I need a rear exhaust box for it They seem quite expensive to buy new so happy to buy secondhand one if anyone has one?
406 '01 110 GTX estate in white, the new tow car.
Re: Wanted. 406 2.2 HDI Coupe exhaust rear box
The Hdi saloon is the same box, but the tailpipe slopes down whereas the coupe goes straight out....
The hangers line up and everything..!!
That's great cheers, that could the difference between £212 and about £40 ish for the one you say will fit! Cheers
Is that a saloon 2.0 or 2.2 or are they both the same? Cheers
On a coupe, all exhausts are the same diameter apart from the 2.0l
The one you need must be from a 2.2Hdi or a V6 saloon, but the diesel one is cheaper, an estate one won't fit as the hangers are in a different place.
There was a thread regarding this on the coupe club ( www.406coupeclub.org ) a while ago, worth double checking before spending your hard earned wonga on duff advice from a ginge....
Just been on-line and it appears the back boxes are all the same for the diesels, but I'm not one to trust eBay 100%.....
Here are 2 links to eBay sellers ( taken from the 406Coupe thread )
PG674G - Saloon ( note the tailpipe ) http://www.ebay.co.uk/sch/i.html?_from= ... G&_sacat=0
PG782X - Coupe ( tailpipe is different ) http://www.ebay.co.uk/sch/i.html?_odkw= ... X&_sacat=0
Here is the Service Box diagrams, just for conformation
https://www.flickr.com/photos/41486012@N02/15753138523/
Hope this helps.
Hope this helps.
The pipe diameters for 110 & 2.2 boxes are definitely the same as they both use 66mm pipe clamps at the mid pipe/back box joint and 74.5 mm clamps at the cat/fap to mid pipe joint. (3.0 and 2.0 petrol turbos use 74.5 mm clamps at the back box too).
I think estate back boxes also have a longe tailpipe.
If you're anywhere near Telford I have a 110 back box in good nick for a few beer tokens, probably uneconomic to post tho if you're too far away.
2003 2.2 HDI SE
2003 2.2 HDI SE
Just put a straight through pipe on Your'll notice no difference in sound
Your all to helpful! Thanks again, I think I'll order one from ecp as its only around £35. Thanks for the offer too of the second hand one but to far for me in Essex!
