Bearing hum from rear?
Blubayou
Post by Blubayou »
Hi Guys,
Coming up to 106'000 and my faultless 406 est has a fault!
This has been developing for a while, and is getting worse (over the last 10'000 or so).
A resonating hum from the rear, possibly offside, which starts about 45mph, hits a resonant 'hmmmm' peak at 54mph & then sinks into the background as speed increases. It is more pronounced with weight in the back but does not seem to change on cornering.
To me it sounds like a wheel bearing, but I feel no play with the wheel jacked up, not graunchy either. I understand these rarely fail?
I have had the offside off today, it was pretty dry on the outer race. Attempted to fit new bearing but the new assembly fell in half on vigorous fitting! Before I destruct things further, should I be looking elsewhere? :frown:
2004 HDi (90) 'S' Estate, (was) just 62'000 OAP miles, now 108'000
1973 Spitfire 1500 - ENGINE JUST EXPIRED!
2005 206 1.4 SW (Wifeys) - Great little motor!
Re: Bearing hum from rear?
This usually turns out to be an out-of-shape tyre, (it's happened to me several times) - try swapping both rears alternately for your spare.
It may not be this, but since it costs nothing you really should rule it out first.
rwb
Post by rwb »
I thought bearings were normally a narrow speed range, and at multiples of particular speeds?
PeterN
Post by PeterN »
Generally the noise will get louder with increased load, so cornering to the right will throw the weight on to the n/s wheel and vice versa. Listen when the noise is present and see if cornering makes a difference.
Blubayou
Post by Blubayou »
Well what can I say?
Thank you Doggy :D
Removed the O/S rear 'Sunny' tyre (24'000 miles 3-4mm tread, Chinese crap), fitted old worn Pirelli 6000 spare, no more hum!
Pair of new tyres for the rear methinks :idea:
That's how we roll. 8)
rwb
Post by rwb »
Blubayou wrote:... 'Sunny' tyre ...(24'000 miles 3-4mm tread, Chinese crap)
I've had trouble with them
Glad it's sorted :)
PeterN
Post by PeterN »
Easier and probably cheaper than a wheel bearing. Well done.
