Stuttering after coil pack change
406Kris
Post by 406Kris »
Hi
I changed my coil pack in October due to the last one failing.
Since then I get a stutter around 1700 rpm and 2500 rpm but the revs don't drop and the speed is constant.
I have noticed that If I put my foot down it does not stutter.
Could it be the coil pack which was a second hand one?
Could it need a fuel filter change and a service?
Does it have to be plugged in to the diagnostics in order to change the coil pack?
Thanks in advance
Kris
406 1.8L 2002
madmadmax
Re: Stuttering after coil pack change
Post by madmadmax »
most likley the coil pack
A service wouldn't go amiss though. I don't think the coil pack needs "coding".
406Kris
Post by 406Kris »
Cheers fellas, might be worth forking out for a new coil pack. :shock:
406 1.8L 2002
406Kris
Post by 406Kris »
UPDATE DESPERATE
the car decided it won't start today
It turns over but won't fire up.
At first I thought it was the starter motor but it's turning over.
Does anyone have an ideas?
Thanks again
406 1.8L 2002
can you hear fuel pump prime?
Work out whats missing.
*fuel
*spark.
406Kris
Post by 406Kris »
Cheers Lozz
Problem is once the coil pack is out I can't check to see if the spark plugs are sparking as the get pushed out of the coil pack.
I read somewhere that if you test the resistance on each pin where the connector goes that it should show one of them as a different reading as the others which would mean a faulty coil pack. But would the whole coil pack go at once?
I haven't checked any of the belts to see if they have snapped yet, maybe next port of call?
It could do with a new fuel filter but it started fine on Tuesday.
Cheers again
406 1.8L 2002
Just a thought,
do you know anyone who has a code reader?
Perhaps a code read..might help take some of the guess work out of whats wrong.
ive got a code reader you can use but im in Manchester.
406Kris
Post by 406Kris »
UPDATE
Well I had breakdown with home start on my insurance, (who knew)
Guy came out and said I had flooded the engine!! :shock:
I took it off drive on Tuesday and not used it until Thursday morning, surely that would have evaporated after two days?
Anyway apparently all fixed now :cheesy:
Cheers for the help
406 1.8L 2002
