207 electrical-gremlin/witchcraft?
anyone any ideas..why a car wouid lock itself?
the 207 locks itself..even if key is in car. ( :oops: )
(it caught me out,-it even dead locked it's self., :?
Re: 207 electrical-gremlin/witchcraft?
Its quite common, its happened lots of times on PSA cars.....
I always leave my drivers door on the latch if I need to leave it ticking over, just in case :frown:
benczuk
Post by benczuk »
My 406 developed a habit of doing this after I had to Jump it because the battery had got too flat.
I think a battery disconnect, leave it and reconnect eventually resolved it.
gumby6371
Post by gumby6371 »
I thought it was a feature PSA fitted after a request from Timpsons
2003 2.2 HDI SE
MixMan
Post by MixMan »
I don't think it's exclusive to PA, had it happen on a Ford and a Rover..... :evil:
I never close the door fully when scrapping ice off etc...
Currently frustrated by: 2002 2.2HDi Executive Saloon
Thanks for the reply's.
found the problem.. both rear light cluster,connectors melted,
not sure why it wouid cause the doors to randomly lock but it does, :?
with them disconnected it dosent do it,
been looking for replacement connectors but no luck, even scrapyard's wont sell them me,,gotta buy the full loom, £70
Maindealer,said they don't sell the conectors or any kit to repair them, not sure what to do next, :(
benczuk
Post by benczuk »
More important question would be why have they melted in the first place!
I would hard wire / make my own connections rather than pay £70 and have to run a new loom.
benczuk wrote:More important question would be why have they melted in the first place!
Thanks..*the connector's have gone on the earth,
the plastic as got hot and melted, (going off google..its common)
they arnt the same as on most pugs, the wires are thin and connectors are realy small,
Bad desighn,
if it was an older car,id make up my own conectors,
ive messaged a few breakers on ebay..hopefully one of them will sell me the conectors and abit of wire,
benczuk
Post by benczuk »
Is it CAN bus? Altering the resistance or adding / removing anything to the circuit can cause all sorts of trouble. (*so I'm told)
Is it CAN bus?
^ Yes (worst luck) :(
Probably unrelated, but my daughters ' 57-plate 307 had some weird faults when the earth pin in the connector to her o/s/r light cluster melted.
I just soldered a wire onto the common connection bars and earthed it on one of the mounting studs. Been fine since.
Doggy wrote:Probably unrelated, but my daughters ' 57-plate 307 had some weird faults when the earth pin in the connector to her o/s/r light cluster melted.
Thanks doggy.
that sounds like a good idea. iwill give it try tomoz. 8)
