I have this fault code pop up every time I drive with gusto, which I initially thought was an overboost issue. I've treated the car to a new MAP sensor and Turbo EV, as well as new silicone vac pipes - I even squirted WD40 into the vanes to try to sort the MIL.
I checked on PP2K and it turns out its a 'short circuit to positive' fault, P0235 which happened at 2891 RPM and the recorded boost pressure was 2518 mbars.... the fault doesn't affect performance ( other than occasionally lacking power on the upchange ) and it will clear itself after a day or so.
Any ideas?
Edit;
Right, I had a few hours on the car today....
Changed the fuel filter.
Removed strut brace to get the engine cover off. I started to remove the EGR, dropped my 10mm spanner down the back of the engine.
Removed the undertray, retrieved the 10mm spanner then I removed the EGR, put some cleaner down it then dropped the screws for the EGR.
Couldn't find the screws so removed Finchies EGR blank from the donor car, put this on my car with a new paper gasket. Dropped a bolt for the strut brace down the back of the engine - no idea where that went....
Removed the Nicopipe as there was a leak, cleaned the edges and put a paper gasket on that too.
Removed a strut top bolt ( albeit a shorter one ) from donor car to refit the strut brace
Took the car for a test drive and the EML light came on straight away, lost my brakes
Came back, removed the vacuum pipe from under the engine cover where it was kinked, swapped the turbo solenoid and went for a drive - EML light back on but brakes working fine.
So I still have the 'short circuit to positive' fault, but the turbo is cleaner.
Went indoors, emptied the dishwasher, had a shower, put some washing on then the wife came home and whinged about me putting a wash load on with the labels still on a pair of jeans ( the jeans that she put in the basket without removing said label - my fault of course )
Not sure what to try next regarding my boost issue??
