colour match?
- 2.2 16v
colour match?
Every time I get some rattle spray cans from halfords/car shops the colour match is poor, I've seen on the interweb places that mix the paint to the code are they any better?
We all know how the paint fades over the years !!
Or is the only way to get a good match is have it done by a sprayshop???
- lozz
Re: colour match?
Hi.
Imho theres nothing wrong with halfords colour match tin's
as you say its the age of the car, or paint fade due to the sun..
Best bet is find a paint specialist they will make you 'proper tins up. Take the car along with you or take a peice of it in, (fuel flap) etc
sounds daft but they will match it better that way rather than just making atin up off paint code,
its normaly around 13-15 quid atin mind,
Re: colour match?
If you use a decent paint colour restorer ( Ferecla G3 Ultra ) or similar, it will bring the old paint up to nearly match the new paint....
- 2.2 16v
Re: colour match?
thanks for the feedback,
I will have to try and find a paint specialist to match the car , the colour is the diablo red which is pearlesent, I have had to rub down the bottom of the n/s/f door as it was rusty all all along the bottom which is unusual for a 406, all other doors ok + small bits where the lacquer peeled off ! The lacquer can be a right pain
Re: colour match?
Probably would work out cheeper & better to find a replacement door
2006 BMW e61 535d m-sport
run's for cover
- 2.2 16v
Re: colour match?
tried to find another door, but hard to find in diablo red !, will keep looking
- lozz
Re: colour match?
Becareful when buying a door,(if you find one)
there is a simalar colour, (wicked Red) diablo is slightly darker,
- 2.2 16v
Re: colour match?
cheers
yes wicked red metalic looks very similar , it was used on earlier 406's .I will be waiting for warmer weather to have a go at the door so gives me some time to do some more searching!
- lozz
Re: colour match?
if its just the bottom of the door & it wont match,
id blow the paint in to the other door, if you get what imean?,
and then (g3) the rest of the car,
leave the paint for a few days before getting the laquer on.
- 2.2 16v
Re: colour match?
opinions needed
looking at the posts on here, they recon that its best to use white primer
Re: colour match?
You can use white it'll make it a brighter shade, if your realy bothered you could find out what's under the std paint
(rub it down until you find the primer colour).
B.T.W theres at least two Diablo red N.S.F doors for sale on the bay a the mo ones £40 + p&p the others £50 + p&p but I'm sure you could work out a deal
In my experiance it's very hard to stop a door rusting once it has started, they tend to rust from the inside out
in a year to two years your back to square
one (minus all the time, money & effort)
1. ebay item no 281645977819
run's for cover
- 2.2 16v
Re: colour match?
Thanks for the info, must have missed that,will ring the guy 2moro.
? Can anybody confirm the doors off an estate will fit my saloon???
Re: colour match?
Fronts, Yes
Rears , No
Rears , No
run's for cover
- Bailes1992
Re: colour match?
Lacquered paints don't suffer with fade too badly, especially metallic and perlesant paints.
G3 won't restore a lacquer coated paint either as it will remove clear lacquer and not the base coat. It's the base coat that would have faded.
The main issue with colour names and codes is there can be thousands of shades of one colour and hundreds of shades of a colour code.
If you take the car to a car paint specialist they can come out with a colour chart of all the different shades of your colour code and get it bang on!
Re: colour match?
I use Halfords all the time, give them the paint code then they mix it from there computer the actual paint is Duplicolour
