wheel bolt wont go in
Re: wheel bolt wont go in
right down on the south coast im afraid. thanks anyway.
If the thread is damaged on the wheel side of the hub, try putting the bolt in from the back with plenty of lube, such as wd40, it might clean up the existing threads.
I wouldnt use loctite to hold it in, you will sruggle with it next time it has to come off and you maybee on the roadside with a puncture
Steve
Steve
bloody brilliant idea coming from the back. will check it out later.. thanks
stevewalsh wrote:If the thread is damaged on the wheel side of the hub, try putting the bolt in from the back with plenty of lube, such as wd40, it might clean up the existing threads.
Steve
You will need to remove the disc and caliper to do this, plus you risk stripping out the threads completely.
Loctite will not stop you undoing the bolt.
Just had a thought about this....I have assumed all along that this wheel bolt is on a front wheel....is this correct?
On the rear it is quite easy to replace the hub as they come complete with the wheel bearing.
yes front wheel. doing rear drop links later so will look at this wheel bolt again, if not will order stuff today and try and retap in week
fixed it. tapped it out and fitted new bolt.
tap £5 and peugeot bolt £3. took 30secs to tap out so great result,way better than changing the hub and bearing.
annie wrote:fixed it. tapped it out and fitted new bolt.
Well done
Good result
Always nice when the fix is so easy, I suspect someone was a bit too quick with the air gun in the past.
2003 2.2 HDI SE
2003 2.2 HDI SE
it could have been a few hundred so very pleased.
still those awful rear droplinks. ordered 406 haynes so will look at manual and then prob take to local garage.
