Lcd screen replacement
BIGDAN
1.6 8v
Post by BIGDAN »
If I replaced my screen with another from a car that didn't have satnav etc would it still work?
Re: Lcd screen replacement
Yes, the Sat-Nav screen has 2 trip computers and a nicer display - the non Sat-Nav has only 1 trip computer and a more basic display.
Its a straight swap though, and replacement bulbs for a non Sat-Nav screen are about £1 for 10 on tinterweb.
BIGDAN
1.6 8v
Post by BIGDAN »
Mine has satnav etc but screen broken so can I plug a non satnav screen in to work?
Yes, its a perfect fit.
It takes a bit to get used too, but at least you'll be able to read the display.
Please don't bin the old Sat-Nav screen, I'm after a spare.... :cheesy:
BIGDAN
1.6 8v
Post by BIGDAN »
I'm not sure it's tge correct screen as I have 2 plugs behind my screen and only one plugs in to it
I'm guessing the satnav won't work on the other screen tho?
There are often 2 plugs behind the display, I'm not sure why but the same one is used for both types of display screen.
You will lose the Sat-Nav function on the non-Sat-Nav screen - buy a Tom-Tom instead... 8)
BIGDAN
1.6 8v
Post by BIGDAN »
That's cool I can live with that as long as everything else works that's fine cheers mate
grasmere59
Post by grasmere59 »
I swapped a sat nav for a non sat nav screen and I lost the remote radio function from the stalk for some reason.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
fattail95
Post by fattail95 »
As far as I'm aware, if you swap a MFD from a semi-mux car into a mux car, or vice-versa, then an option in the displays ECU needs changing so it can pick up the right signal. Very easy to do if you have PP2000.
2001/Y Peugeot 406 2.0 HDi Saloon
150hp/330nm Powerflow stainless exhaust Kevlar clutch Cat delete EGR & Doser delete Leather interior Windows tinted Cruise control 5 dial cluster Yatour bluetooth Starfish alloys Twin rear fogs
Ah, so maybe aim for a replacement display from a car from the same year, give or take..
I have had no issues with screen swappage, but all my 406s have been 2002 or newer ( fully mux )
Did we ever work out what the other plug was for behind the MFD ??
grasmere59
fattail95 wrote:As far as I'm aware, if you swap a MFD from a semi-mux car into a mux car, or vice-versa, then an option in the displays ECU needs changing so it can pick up the right signal. Very easy to do if you have PP2000.
Ah that would make sense then as the display i used was from a semi-mux car and i put it in mux one.It made no difference as i was selling the car on so i removed the radio stalk from the column comms unit so the chap i sold the car to didn't know any difference :oops:
paniya88
1.6 8v
Post by paniya88 »
My car lcd display part no is 9641902577 A00 and found a replacement part with same no but R00 instead of A00. Will it be compatible with my car?
frog
Post by frog »
paniya88 wrote:My car lcd display part no is 9641902577 A00 and found a replacement part with same no but R00 instead of A00. Will it be compatible with my car?
Are you sure that "R00" is not a misspelled "A00"? misspelled by Chinese who cannot read our alphabet, or by a crappy OCR software? "A" and "R" look alike :cheesy:
googling "9641902577 A00" gives a long list of results, but googling "9641902577 R00" gives none ...
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
