Potatometer
kris
Potatometer
Post by kris »
Evening all. Looking for a throttle potentiometer/position sensor for a 98 2.1dt or one that will fit it. Looked on ebay/ecp/gsf, cant feckin find one for the life of me. Can anybody help?
D8 ('98) 2.1TD LX Long-Wheel-Base Hatchback.
PeterN
Re: Potatometer
Post by PeterN »
If it was a radio or TV I could help you but I suspect there is something special about this one, probably in its mounting. If its a conventional pot which I doubt you need to know its value.
kris
Re: Potatometer
Post by kris »
I have no idea to be honest. Think I'm gonna have to phone the dealers Monday morning on the remote off chance they have one/can get one.
Bailes1992
Re: Potatometer
Post by Bailes1992 »
All the throttle position sensors fitted to the 406's are the same. I believe the only petrol with a fly by wire throttle was the 2.0 HPi. Other than that any diesel pedometer will work fine.
kris
Re: Potatometer
Post by kris »
Will it be ok to use one with the 4 pins in a square shape opposed to 4 pins in a rectangle shape which mine is originally? There's a couple on ebay from HDI's, but use a different plug shape.
kris
Re: Potatometer
Post by kris »
Also... The one on my 98' looks to have rotational adjustment. HDI ones look to have a fixed position. Will that matter? As long as its gonna work I'm not too worried lol
Re: Potatometer
Well, it's "supposed" to be the same part...
1920 X1
Crikey, 309 quid from Pug :shock:
kris
Re: Potatometer
Post by kris »
Oh feck lol right well I'll no be phoning the dealers Monday morning, not at that price.
PeterN
Re: Potatometer
Post by PeterN »
I think the Xantia and 406 use the same one.
KozmoNaut
Re: Potatometer
Post by KozmoNaut »
Bailes1992 wrote:All the throttle position sensors fitted to the 406's are the same. I believe the only petrol with a fly by wire throttle was the 2.0 HPi. Other than that any diesel pedometer will work fine.
I believe all D9 petrol 406s are actually throttle-by-wire, my 2000 semi-mux 2.2 petrol certainly is, and I cannot see why later full-mux D9s wouldn't be.
It's just a tiny bit confusing since the potmeter is located in the engine compartment and actuated by a throttle cable. "Best of both worlds", as they say.
2000 406 TS4 2.2 saloon
PeterN
Re: Potatometer
Post by PeterN »
I think that was done so they could drop the engine straight into cars that previously used a throttle cable. That is certainly the case with the Citroen XM, all the electronics are contained on the engine so it can just be plugged in and the throttle cable connected to the pot. I would have thought that all the 2.1's with the EPIC pump, '96 on' would have been the same.
Re: Potatometer
jasper5
Re: Potatometer
Post by jasper5 »
The HPi has a throttle position sensor operated by a cable just like all the others.
kris
Re: Potatometer
Post by kris »
It's this bit
http://m.ebay.co.uk/itm/peugeot-406-307 ... nav=SEARCH
But mine has a different plug on it. The car's at the garage to get it diagnosed just to make sure it is the pot that's the problem. What else it could be I don't know, but its more for peace of mind before I pay for replacement parts and start chopping wires and whatever.
Stenasev
Re: Potatometer
Post by Stenasev »
kris wrote:Evening all. Looking for a throttle potentiometer/position sensor for a 98 2.1dt or one that will fit it. Looked on ebay/ecp/gsf, cant feckin find one for the life of me. Can anybody help?
Hi,
I have one with the terminals in a square pattern if you need it.
Steve
2003 406 2.2HDi SE Estate Manual - Sold
