Major water leak
Major water leak
Hi guys I have a massive water leak on my hdi 90 from the middle of.engine tray at the back need help diagnosing seems a lot worse when engine running. I put 2 litres of water in it this morning and as soon as I stated it up it streamed out. Could it be the water pump someone said it could be a pipe coming off the pump has gone has anyone got any pics of Wat it looks like need car for work cheers
Les medecins choisissent www.viagrasansordonnancefr.com traitement efficace
Re: Major water leak
Best to get it jacked up..undertray off if it has one and have a look.
Obviously when its cooled down.
Do u have aa or rac..
I don't think there is a pipe coming directly off the waterpump. There is a water manifold at the rear of the engine which might be the right place but it could be running across the undertray from anywhere. As Lozz says, best get the tray off and get under it to look, otherwise you're just guessing.
Water mqnifold has a pinprick in it
