First thing this morning
AAAAAAAAAAAAAAAAAAAAAAAHH!! The house will fall down! Er no, it won't. As has been pointed out to me, houses here are built from these silly pottery bricks but a frame is made around them using steel reinforced concrete. If you knock a wall out of a UK house it'll probably fall down, but these houses, if you remove all 4 walls (in theory) they'll stay up.
Shuttering.
It's a bit council estate to me but this was my suggestion right from the start, the only way I could think to lower the steps up there and leave them wide enough to still be useful.
These are interesting:
He's using these to hold up the side of the form there and I reckon it shows how Croatian builders don't trust these pottery bricks for anything.
On the one side is a bit with a wedge, you take a steel wire (I measured it at 6.85mm with my shiny new Chinese vernier gauge
) and use the wedge to trap it in the clamp:
On the other the wire goes through it and then you use a special spanner (which is a tube with a knurled snail to pull on the wire and a big knob on the end to wind the snail up) to tighten it all up and then you hammer the wedge in to trap it:
Reinforcing going back:
This also shows the lack of faith with the bricks:
the board at the back there is actually hanging off the roof beams, it's only pinned in one place at the top, into the concrete deck (I see they trust that one)
More reinforcing:
Here come the steps:
That's it for today. I guess he must be almost ready for the pour.
I did ask Miloš to explain how the pour works but it got a bit tricky with the language so we decided I'd see it when it happened. I was expecting him to make tops to the steps and pour it all in from the top but I'm beginning to suspect that maybe all my ideas are actually misconceptions and the concrete won't end up everywhere. Time will tell I guess.
Btw I asked Miloš how many set of these he's done, hundreds apparently, and many far more complicated with multiple turns and all sorts: so I guess we're in safe hands. Hopefully.
