I got new information.
I meassured the fuel pump relay and the result is:
- Pin 1, 2, 3, 7, 8, 9, 11 and 15: 12 volt
- Pin 4: 0,7 volt
- Pin 10: 0,94 volt
I assume the ECU is not faulty since the relay is fed with power?
I assume the relay could be the troublemaker?
I assume the anti theft thing is working since it is beeping with the key in the ignition and op en door agter trying to start the engine?
Is there any sensor that will cut the fuel pump if there is sufficient fuel at the engine?
I am ready to hear your thoughts about my thoughts
