Unfortunately this has opened up a whole new can of worms so I'm afraid I am going to be pestering you again. The 406 diagnosis is telling me that the ECU is the wrong one for the engine, presumably that means that its corrupted. I have seen adverts for sorting them out but as the car has done 245k miles and is a bit tatty I obviously don't want to spend a lot of money on it. Someone just down the road has offered me a complete 406 for free if I take the lot, what is the situation regarding swapping them and the key transponder?
The C5 will not talk to the lexia, it says insufficient information or something similar although you can get into the diagnostics - I can't remember how but if you bring the car details up it is showing the correct VIN, but everything you try and connect to comes up no connection.
I think this car has a faulty injector as when it gets hot it ticks over like a sick pig, I have done a leak off test but it is inconclusive, all the outputs are very similar with one being slightly higher.
Can anyone help?
Thanks, Peter
PeterN
