hi ,
after about 2 months i just received the pp2000 interface today ,a Chinese clone .
installed diagbox 7.02 in win xp sp3 virtual machine and hoked up to diagnosis socket and run the peugeot planet from the diagbox.
then did a global scan and its only read the engine ecu ,airbag ecu and abs ecu
bsi - the ecu has not reply
air condition ecu - the ecu has not reply
then i install diagbox 5.02 and scan again so the results are same just read engine ecu, abs ecu and the airbag ecu.i am able to do configuration actuator test in engine ecu and abs ecu .
but i want to check that the ac compressor cutting in or not by using pp2000 actuator test .
is actuator test for ac compressor clutch under the air condition ecu on pp2000 ?
why it does not recognize my bsi and ac ecu ?
thanks very much
