This could easily be another dumbarsed question, but,
Can pump timing cause problems on common rail Pugs?
It seems to be issue with VAG TDi's, looks like a right old faf.
Hdi pump timing?
- 2.0 Turbo
Hdi pump timing?
- jonsowman
Re: Hdi pump timing?
I don't believe the HDi pumps are timed. As long as they're being spun by the cambelt they'll be fine.
+1, no programming or timing necessary.
+2, no programming, timing, camshaft replacement or ear defenders necessary.
.... assuming that the camshaft and crankshaft are synchronised, the PP2000 says mine are but could it tell if it was one tooth out? I am about to find out soon. The injection advance is correct according to the lexia but would it be if it was a tooth out?
The real answer to the original question is quite correct, the injection pump is purely a high pressure pump to maintain the fuel rail pressure - so it doesn't need to be timed, the timing is all done by the ECU - assuming its being fed with the correct information.
