406 2.0 hdi lowering springs
calomon90
Post by calomon90 »
I'm wanting to lower my 406 2.0 hdi and I cam get 40mm spring just out of intrested how low will it be I've got 17 inch challengers on it and the front seems to sit high all I want is less off an arch gap will I get this will 40mm springs
Re: 406 2.0 hdi lowering springs
Yes, 35mm seems a normal reduction for the 406, Apex are well liked and about £130 for a set.
Some have lowered their cars by over 60mm with Challengers with no issues, but this is too low for my liking.....
dirtydirtydiesel
Post by dirtydirtydiesel »
In my opinion the 406 sits to high at the front.
Wietec do some springs that are 40mm rear & 60mm front in reality it drops 50mm at the front & 30mm at the rear.
notrix
Post by notrix »
I just lowered my 406 2.0 HDi Break with 35mm. springs from H&R. Very satisfied with the result. The car looks so much better and drives better too.
This is with 18" Peugeot 308 wheels with 20mm. spacers and 225/40-18" tires on them making the car higher off the ground than on stock wheeels, but the wheel gap is spot on.
dirtydirtydiesel
notrix,
Your car looks great with those wheels but the tyres are too pricey for me :roll:
peo
Post by peo »
I like so much these 308 alloys in 18". Your car is really fantastic, I would like to lower 3 cm but with Eibach springs.
Peugeot 406 HDI SR Pack Fase II 2004 with Brembo calipers and strut force
batrst
Post by batrst »
notrix wrote: Thu Jul 28, 2016 12:57 pm I just lowered my 406 2.0 HDi Break with 35mm. springs from H&R. Very satisfied with the result. The car looks so much better and drives better too.
have you a close up of front and rear arch was gunner put h&r on mine on 18" 205 /45/18 so wonded how colse it was
notrix
Post by notrix »
batrst
Post by batrst »
yes great mate .so you just put springs on you not got different shockers
notrix
Post by notrix »
batrst wrote: Thu Dec 23, 2021 1:36 am yes great mate .so you just put springs on you not got different shockers
That's right.. I just reused the original shocks.
batrst
Post by batrst »
notrix wrote: Thu Dec 23, 2021 2:00 pm
what numbers was on your front springs as got H &R springs but they dont fit my shockers fronts are 29788 va
notrix
Post by notrix »
The kit I got was HR29788-1
I had no issues fitting it as far as I remember. Which part of the shock tower are you struggling with?
batrst
Post by batrst »
thats the kit i have but my car has smaller shockers on so fronts dont fit
batrst
Post by batrst »
found mine had different socks on front but sorted now .
notrix
Post by notrix »
Good stuff 8)
Sadly both my 406's suffered from old age and rust and are now long gone..
Sticking to French cars I moved on to 508's and currently have two pearl white 508SW HDi's
Would love to see a picture of your car when you're all done :)
