In-car chargers
trem1
In-car chargers
Post by trem1 »
what do we know about in car chargers??????
can i make my own up or not??
is it just a case of cutting either end off and connecting the same coloured wires???
i want to make an in car charger for my camcorder but everywhere wants silly money for one £30.00 is silly money to me
come on guys what do we know any ideas???
Benner
Post by Benner »
As long as you get the polarity correct, it should be no problem.
Just check that there is nothing inside the chargers plug (you can find strange things sometimes)
Put it this way, normally the plug is just wires connected to different terminals and if a charger is available, this should not be a problem.
What voltage does it quote on your mains charger?
You need one of thesemate. Then use the mains charger.
150W is probably enough for your camcorder charger, but it'll say on there somewhere. I've got a 300W one for running my laptop in the Zook so that I can use the GPS with electronic OS maps. Think it was about £30 from Maplins.
Benner
Post by Benner »
Put it this way, my TomTom adaptor has an output of 5v I think, so the voltage is stepped down. In this case, 12v would kill it.
However I have a rechargable torch which has a mains charger with an output of 6v but the car charger has an output of 12v.
Really, to do it you should be matching the voltages of the in car charger with the mains adaptor. By using a mobile phone in car charger, you should be pretty close I'd expect.
Edit: I'd get what Dai has suggested :arrowu: You're completely covered then.
trem1
Post by trem1 »
how would i find out the output of a in car charger :?:
Benner
Post by Benner »
It is probably written on it somewhere.
To be honest I'd get what Dai has suggested, I didn't realise you could get them as cheap as that.
That way you know you're safe :cheesy:
Benner wrote:As long as you get the polarity correct, it should be no problem.
WRONG!
Never try to charge things by just throwing 12V at them! If all that happens is you fry the device, you'll be lucky - batteries (especially lithium-ion) really can explode violently - see http://www.youtube.com/watch?v=WeWq6rWzChw
You need a charger which outputs the correct voltage(s) at the correct current. I just charge my stuff up using the mains charger and an inverter.
Benner
Post by Benner »
Benner wrote:Put it this way, my TomTom adaptor has an output of 5v I think, so the voltage is stepped down. In this case, 12v would kill it.
This is why I put this :arrowu:
Think I was unclear before.
