Clutch 406 hdi 110 glx 2003 estate
- Newbie
Hi can any tell me what sort of clutch I need and what make of clutch as I have looked for parts on line they differ from 90 to 300 pounds not fitted.also how much should I pay laboure many thanx
Re: Clutch 406 hdi 110 glx 2003 estate
Curryman123456 wrote:Hi can any tell me what sort of clutch I need and what make of clutch as I have looked for parts on line they differ from 90 to 300 pounds not fitted.also how much should I pay laboure many thanx
You will need a LUK pull type clutch plus a dual mass flywheel.
The parts will probably cost about £130 for the clutch and about £300 for the dual mass flywheel.
Labour will be 5 or 6 hours at the local rate.
A rough guess...total £750 depending on local labour rates and vat.
I did mine earlier this year, I can confirm that the o.e clutch is LUK,
There's a seller on eBay at the moment parts2clear offering a complete kit with the DMF
For £303.95 including p&p.
I fitted mine myself, I've done a few clutches & this was far & away the hardest
I had a quote from my local independent at 8 hour's @ £50.00 per hour
So jaspers about spot on.
2006 BMW e61 535d m-sport
run's for cover
- Newbie
Omg mmmm 750 can I get a kit to convert it from dule mass to solid ??
- Newbie
Many thanx mr deisl would you like a job lol I live in de2??
You're welcome, glad to help!
yes you canCurryman123456 wrote:Omg mmmm 750 can I get a kit to convert it from dule mass to solid ??
Sent from my iPhone using Tapatalk
Still looking at £240.00 for the kit with the solid mass flywheel & same cost to fit,
The D.M.F's on 406 generally last really well with most doing over 150k on them.
Mine had done 107k + it's remapped to approximately 150bhp & I tow a fully laden caravan with a fully laden car
This made my clutch start to slip when attacking big Welsh hill's & my D.M.F had just started to rattle very slightly under hard loads.
So a no brainer to change it whilst doing the clutch, in fact I'd always replace both together due to the amount of work & time involved.
Peugeot fitted a D.M.F for a reason, to reduce the harshness of the diesel power delivery to the transmission & through the crankshaft
How many miles has your car done? , how many do you think you'll do in it after replacement & your only saving £64.00.
run's for cover
- Captain Jack
I wouldn't recommend converting to a solid flywheel - it'll be rattles galore
