Wipers blowing fuse
Valandil
Re: Wipers blowing fuse
Post by Valandil »
Hmm ok, sounds like it is probably worth trying to fix mine then. Thanks guys!
Valandil
Post by Valandil »
Finally got a chance to look at this tonight. Sure enough that voltage suppressor had split clean in two! Soldered a new one in and seems to be alright so far :cheesy:
Thanks for the help!!
frog
Post by frog »
Good :D Glad you got it solved!
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Splendid news, well done :cheesy:
Voltage suppressor? Was it that diode? Any pics? :supafrisk:
Valandil
Post by Valandil »
Yes it was the one from that French forum posted near the beginning. The spec sheet called it a voltage suppressor. Sorry didn't take any pictures, I was in a rush!
Not to worry, I'll have to see what I can glean from the French site.
I'm annoyed the BM34 diagram doesn't show it, I guess it suppresses the voltage going the wrong way, maybe when it passes the park position :?
