Backplates
exec406
Re: Backplates
Post by exec406 »
I've got new wheel bearings/hubs ready to be fitted with new back plates.
In the video below, at 2:50 you can see 'hub bolt indent' being removed. Is this a factory fitted item? I can't seem to find any for fitting with new new hub / bearing. I take it this indent is a safety feature (preventing hub bolt loosening)
https://www.youtube.com/watch?v=XgOw5SFb6J0
2003, '03' 406 Executive 2.2hdi 136.
Re: Backplates
It's just where the lip on the hub nut is staked (=hammered) into the slot in the stub axle. All you need to do is punch it clear so the nut can turn.
dirtydirtydiesel
Re: Backplates
Post by dirtydirtydiesel »
Always use a new hub nut & once you have torqued it to the correct setting you stake the new nut with a punch or a flattened cold chisel into the indent in the stub axle.
jasper5
Re: Backplates
Post by jasper5 »
exec406 wrote:I've got new wheel bearings/hubs ready to be fitted with new back plates.
I've mentioned this before in other posts, but here is a reminder....
Remove the hubs before you try to do any work on removing the handbrake shoes...it will make the job a lot easier.
When you have fitted the backplates make sure you fit everything related to the handbrake, including the shoes, before you fit the new hubs/bearings...it will be much easier to fit the springs and shoes with the hubs out of the way!
The hubs/bearings should be the last thing to be fitted before the drum/disc.
In the video it shows fitting the hubs before the shoes! This is just making life difficult for yourself!
Re: Backplates
On the subject of backplates anyone see these recently:
http://www.ebay.co.uk/itm/PEUGEOT-406-1 ... SwE6VXJJ~v
dirtydirtydiesel
Re: Backplates
Yes Frank, there's also a link from the coupe club to some for £31.99 a side 8)
Re: Backplates
peugeot-406-brake-back-plate-2003-estate-passengers-side-rear
:roll: :roll:
http://www.ebay.co.uk/itm/232042011528? ... noapp=true
dirtydirtydiesel
Re: Backplates
I have took the plunge and purchased a pair of the Klokkerholm replacement backplates :shock:
And I am pleased to report that they are great quality, they are even galvanised 8)
A massive saving over O.E, £79.00 the pair delivered compared to £105 each + vat O.E :cheesy:
I'm going to get them powder coated at work as well just to be safe.
So if anyone's unsure about these let me reassure you that there just the job :)
I will post up pictures of the job
Here's the said backplates :
P.S if anyone's got some old scrap one's with the caliper mounts still there, I'd happily give a few beer tokens + p&p
for them :cheesy: .
Cheers DDD.
fattail95
Re: Backplates
Post by fattail95 »
They look brilliant 8) good price too!!
2001/Y Peugeot 406 2.0 HDi Saloon
150hp/330nm Powerflow stainless exhaust Kevlar clutch Cat delete EGR & Doser delete Leather interior Windows tinted Cruise control 5 dial cluster Yatour bluetooth Starfish alloys Twin rear fogs
ridgie74
1.6 8v
Re: Backplates
Post by ridgie74 »
i have two new unused peugeot backplates for sale. I bought them new from peugeot, so complete with calliper brackets, and ready painted black. 60 quid each. if anyones interested.
grasmere59
Re: Backplates
Post by grasmere59 »
I could do with an O/S one,how much posted?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
runner1
Re: Backplates
Post by runner1 »
Re: Backplates
Nope, probably because the seller has invented a new name for them :frown:
The rather look like the Klokkerwotsits for a grossly inflated price...
Re: Backplates
Why am I thinking that in a few years time there will be meetings in remote corners of car parks under cover of darkness where exchanges of dubiously-sourced Peugeot back plates will take place for many monies.
dirtydirtydiesel
Re: Backplates
There the ones I bought & the same seller, the price has only gone up £5.00 since Brexit :roll:
