Advice on niggly issues...
Re: Advice on niggly issues...
Always happened - pretty much since owning. Remap/deFAP/deEGR was only recent.
You get the jolt when coming off and on the throttle pedal? How does EGR go in play here?
Bailes1992
Post by Bailes1992 »
Captain Jack wrote:Always happened - pretty much since owning. Remap/deFAP/deEGR was only recent.
Also get it if I'm cruising at very low engine demand situations and I give the accelerator a press. One bit of live data I have you can see my TPS goes from 6% to 62% and the EGR opens. :roll:
Hm, well, it does happen when cruising but only when I come on or off the pedal. If the wheels are already being propelled by the engine and I give it the bean then there are no jolts. Which is why I suspected the knackered dampening on the flywheel - no dampening would cause sudden jolts as the engine is engaged/disengaged.
barbaren
Post by barbaren »
Captain Jack wrote:Hm, well, it does happen when cruising but only when I come on or off the pedal. If the wheels are already being propelled by the engine and I give it the bean then there are no jolts. Which is why I suspected the knackered dampening on the flywheel - no dampening would cause sudden jolts as the engine is engaged/disengaged.
automatic or manual?
Sent from my iPad using Tapatalk
Manual...
barbaren
Post by barbaren »
Then try to disconnect the clutch control switch. See if that does'nt help. If it does your troubles are over.
Have been strugling with mine, it started like yours, then little by little it became worse, cutting out for just a split second when accelerating. Disconnected the the switch, and voila it stopped. Fitted a new one £9 on Ebay. No issues since.
Er... what does clutch switch have to do with anything? I don't have issues with the clutch. And which issue are you referring to?
barbaren
Post by barbaren »
Just try it.
Very interesting about the clutch switch - had no idea it affected response. How many are there? Asking as I have cruise control and it works OK, so surely the switch it at least open, though doesn't necessarily mean CC will switch off with pedal down. Will check with PP tomorrow to see if the switch is functioning.
Is there a way to test the MAF other than cleaning or disconnecting it? Don't really want to spend £80 on a new one if my current one isn't faulty.
barbaren
Post by barbaren »
Captain Jack wrote:Very interesting about the clutch switch - had no idea it affected response. How many are there? Asking as I have cruise control and it works OK, so surely the switch it at least open, though doesn't necessarily mean CC will switch off with pedal down. Will check with PP tomorrow to see if the switch is functioning.
my cc also worked fine. Try to start the car in first without the clutch pressed, if it jumps forward the switch is bad. There is only one switch. Of course the cc will not work once you have disconnected the switch. It will also come up with a fault in pp 2000.
But it doesnt cost anything to try, and if it is faulty its only £9.
barbaren wrote:Try to start the car in first without the clutch pressed, if it jumps forward the switch is bad
That describes how any car would behave, I'm confused :?
barbaren
Post by barbaren »
the clutch control switch will not let you start the car without the clutch pedal pressed.
My clutch switch seems fine. What isn't fine is the car (or rather PP2000) always says that I am in neutral, when I can be in any gear....
Eh? :shock: Is that stationary or in motion? I think it calculates the gear by comparing the engine and vehicle speeds (via abs sensors), so it'll be clueless until it's moving.
I suspect you know this... :oops:
Ah... OK. I thought it would know from gear selection rather than calculating it.
