hunting idle ........ and 'tick tick tick'
yes hunting is when its revs up and drops around whatever revs it should be at, but cant sit constantly at the correct revs. mines only does it when the car is idling. That suggests that one of the sensors is dodgy.... or.... theres is air leaking into the system between the throttle body and engine head, a sensor is picking up on this and trying to supply fuel to compensate for the extra air, but just cant get it right.
I'm still a bit wary(sp) of whether an injector could be making this ticking noise. It sounds more like a valve/lifter clicking against its seat. Do these cars have hydraulic lifters does anyone know?
- 1.8 8v
tick,tick,tick
mines a 2.0 ltr 1998 and has had a tick for ages, it`s more annoying than anything. I also had the revs "hunting" some time ago, that was the stepper motor.
Am I the only clown here?
Have just looked today and mine seems to do the same thing!!
I knew I had a faint tapping, but after reading this I thought I'd look at my rev counter and it seems to fluctuate just above and below 1000rpm. This was not long after start up though and I forgot to look again at the end of my journey, so it may have just been a start up thing.
philg, you say yours does it. How much does it fluctuate by?
- Captain Jack
If you lot had the mighty diesels, you'd have none of the hunting. It would sit rock solid on 850rpm
I don't know anything about petrols, but I know my housemate's Rover
does it and my ex-boss's Skyline... all "hunt" around, especially when cold.
- darrenwall
- 2.0 Turbo
