Map sensor vacuum pipe
- 1.8 8v
Just a quick question, is the vacuum pipe that connects the map sensor to the intercooler the same diameter at each end? The reason I ask is that it feels like a larger diameter on the intercooler side, it maybe due to oil contamination swelling the rubber hose!! Just thought I would check before I disturb it.
- jonsowman
Re: Map sensor vacuum pipe
It certainly has different diameters on the 2.2 HDi, so probably on the 2.0 110 HDi too...
Same sensor on both engines IIRC
- 1.8 8v
Thanks chaps, I thought as much. .
