Timing Belt Tension? [More to story...help?]
Gazaka
1.6 8v
Re: Timing Belt Tension? [More to story...help?]
Post by Gazaka »
Jasper5 wrote:The tension has to be set wrong in the first place. Heat could alter the tension making it too tight then eventually the water pump bearing fails from being under too much pressure.
I've repaired this situation a few times over the years.
Some people do not allow the tensioner pulley to turn after tensioning the belt...you must set it so that the tensioner pulley can be turned with slight resistance from the belt....if you can't turn the tensioner pulley after tensioning it's too tight!
I've done more than 60 of these timing belts.
Thanks for the reply Jasper :)
It makes a lot of sense now, since the belt was the first time it had been done for a long time, as well as water pump. If they just did the tension and then didn't allow for that, explains why first water pump died and for all this trouble. I'll see what they say when I head there tomorrow. Failing that, will need to find somewhere that could help out, as a job to do on the car... how complicated will it be? I understand that the timing belt be be hard to get access too, just thinking if I go to another garage they may end up asking stupid prices just to actually "diagnose". I will see what original garage say first and take from there.
jasper5
Post by jasper5 »
If I remember, you live in my neck of the woods or close by, so if I can help just shout!
Gazaka
1.6 8v
Post by Gazaka »
jasper5 wrote:If I remember, you live in my neck of the woods or close by, so if I can help just shout!
Thanks Jasper5, you're up in Blackburn right? Yeah not too far, I'm back in Bolton again. I might ping you a DM sometime. Work 9-4 Mon-Fri currently, with a week off first week in Easter. Going to see what they say/do first. Either way, I might ask to come see you for quick look if you wouldn't mind :)
jasper5
Post by jasper5 »
See how you get on.
Let me know if you need help.
Gazaka
1.6 8v
Post by Gazaka »
Thanks Jasper5. Sorry late reply.
Update so far, been booked in for new water pump and timing belt and tensioner all under warranty, so hopefully this gets it resolved.
Edit: removed wall of text about faulty electrics. Figured it out, love the French electrical system...
