Genuine 85k 2.2 executives are like rocking horse poo
The rear axle has collapsed so will need rebuilding. I started taking the axle off but then I realised I had bugger all change of getting any parts for it whatsoever so I gave up.
the rear axle collapsed so I started poking about underneath and quickly got way out of my depth after breaking one of the brake hoses.....
the rear axle collapsed so I started poking about underneath and quickly got way out of my depth after breaking a fingernail.....
There's your problem, the car hadn't been looked afterdirtydirtydiesel wrote:F.P.S.H
car will need to be picked up with a dustpan & brush
Err, aren't they meant to do that?it failed the mot on the brake pedal creeping to the floor under pressure. A new master cylinder was fitted, but hasn't solved the problem.
