406 Hdi auto lights
PeterN
406 Hdi auto lights
Post by PeterN »
My auto lights have suddenly stopped working with the result that i find myself driving in adverse conditions with no lights on. :shock: If you press the button on the stalk it comes up 'auto lights active' but they aren't, the auto wipe also seems to have packed up. Any suggestions?
Thanks Peter
Re: 406 Hdi auto lights
Friday 13th?
Early Haloween?
Suspect your BSI has spontaneously unconfigured some options for you.
Try a BSI reset or PP2K
PeterN
Post by PeterN »
I was going to try a reset but didn't want to have to set the clock again. :frown: I will try it, thanks.
Alternatively, both are controlled by the same sensor, the one at the top of the windscreen...
PeterN
Post by PeterN »
Thanks that had occurred to me, could be a supply failure, I will try the course of least resistance first and do a reset.
I seem to remember the wipers will revert to a basic intermittent program if the sensor goes wrong.
PeterN
Post by PeterN »
Yes, they work OK on manual but just not on auto.
I accidentally 'unconfigured' auto wipers just after getting my current 406 while enabling the auto rear wiper.
The front wipers then didn't work at all in the intermittent/auto position.
IIRC you can have auto, normal intermittent or nothing at all.
