Plip key battery replacement
My mfd on my 2003 hdi has started telling me the plip key battery needs replacement,knowing French electrics is it just a simple task of changing the battery in the plip key or will it mess up something i.e. the central locking etc?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: Plip key battery replacement
Fear not
I've changed mine twice with no nasy side effects
2006 BMW e61 535d m-sport
run's for cover
- 2.0 Turbo
Yes that is an easy job.
I would advise you to have the replacement battery at hand, so that you can quickly insert it as soon as you've removed the old one. All this "french" (in fact german) electronics seems to not like being deprived of juice for anything over a minute.
Also i remember the advice to not touch the replacement battery with your fingers, as the stuff on your skin might cause a leakage path that will deplete the battery sooner than necessary. If you use a set of tweezers / thumb forceps (right word?? Dutch = "pincet"), use a plastic one, a metal one will cause short-circuit.
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 710.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
How do you know if the plip is actually sending a signal or been short circuited when changing the battery?
- 2.0 Turbo
There are testers for this, see e.g.:
https://www.ebay.com/sch/TV-Video-and-H ... +RF+tester
The frequency is usually 433 MHz.
Might work, i have no experience with these devices.
Current "fleet":
Previously owned:
Previously owned:
