Doggy wrote: ↑Wed Apr 11, 2018 5:32 pm
Could well be the problem. Did we determine if your car has a Bosch or Siemens fuel system?
It has a Siemens fuel system. I've changed HP pump including it's pressure regulator, 3 injectors, glow plugs, glow plugs rely, coolant temp sensor, ECU.... and none of these bring any improvements. Even now when on the day are 20+ and on the night 10+ celsius degrees, it still needs 3-4 engine spins to turn on...
Next week, a proper mechanic, not me
, will connect an hose to directly from HP pump to a bottle with diesel, and also the flow back to the same bottle... I guess it's the cheapest way to check if it's a "fake air" in the engine, problem. I hope I explained it properly depite my bad english.
