Wiring in a tow bar
Wiring in a tow bar
I am trying to wire in a towbar into a 2003 estate. Can i wire directly into the lights or do i need to use any fuses oe modules?
Re: Wiring in a tow bar
The car I removed mine from was professionally fitted & that was scotch locked into the lighting circuit .
2006 BMW e61 535d m-sport
run's for cover
To keep it legal you need a light or audible sounder to confirm the trailer indicators are working.
Easiest route is am aftermarket buzzer like this, (just the first one I found at random) https://www.ebay.co.uk/itm/Universal-To ... 0826212148
That all came from the car I removed it from.
Farmer have you bought a new kit or a second hand one?
If you've boughta new kit everything you need sould be there.
run's for cover
- Newbie
Professionally fitted using scotchlocks not very professionally I always solder the jointsdirtydirtydiesel wrote: ↑Fri Jun 01, 2018 11:44 pm The car I removed mine from was professionally fitted & that was scotch locked into the lighting circuit .
I bought a V6 estate with a factory fitted tow bar but looking at thw factory wiring it looks a tad hard to replicate. My motorfactors sold me A smart relay box. Seems to Beep If a trailer is attached, it needs a permanent positivedirtydirtydiesel wrote: ↑Sat Jun 02, 2018 12:21 pm That all came from the car I removed it from.
Anyone used BH15A from the left hand light cluster? It seems to not be used and looking at SEDRE diagrams it doesnt go through the bsi
Just checked through my old posts,
It's terminal 4 on the near side, pop a 20amp fuse into holder 15
As I said mine was removed from another car which it had been fitted to by the after market company Towsure.
run's for cover
