Indicator stalk was in a poor state the slightest touch had me indicating left and right, so got a new plastic spud and spring from eBay and fitted now they work perfectly.
Although now my horn has stopped working since taking the com 2000 unit off, upon inspection I find I am not getting 12v to the horn push on back of the airbag. I am not getting 12v at the plug that comes from inside the com 2000 unit so I fear I may have broken the ribbon cable when I was removing or working at the unit.
So I now plan to wire the horn to a push button or switch as I do not want to replace the whole unit and I only need the horn to pass mot as I never really use it. I have found some diagrams on google which show the feed is from fuse 5 in engine bay (have checked it btw and it’s fine) I need to find the relay for the horn it may be relay4?? But can anyone tell me where it’s located? Engine bay or under steering wheel? Pics of actual location or diagram would be great. Hope this makes sense, thanks!
