However, i now hear a very light whining noise. It is only there when the engine is hot. Only at around 1400-1700 rpm, so not while idling. It cannot be heard when cruising on the motorway. Only when driving slowly at relatively low revs it can be heard. Looking under the bonnet with the engine running and revving a bit, it can be clearly heard that the sound comes from the cambelt area. It is not the drive belt (which was also renewed, btw).
I'm sure it is not the cambelt squealing on a seized (tensioner) pulley. I know that sound, this is way softer.
Googling i came across http://forums.tdiclub.com/showthread.php?t=289928 and http://forums.tdiclub.com/showthread.php?t=312026 . Quote:
"ive done thousands of tdi timing belt jobs and found some do whine especially the gates belts"
By chance, the new belt i bought is a Gates.
Other qoutes:
"You can decrease it by backing off the tensioner somewhat, it will be less loud but still present, you just have to be prepared to readjust the tension intermittently(probably at least once a year"
"the noise is normal - the new Kevlar (in my case Dayco) belts make that noise.".
Does anyone have experience in dealing with this issue? Did anyone loosen the tension? Or should i just accept this and live with it?
Thanks!
