only seems to happen if i'm gunning the engine. i get a seriously strong wiff of petroleum from my 1998 2.0L16v 136bhp. i open the bonnet and theres fuel dripping from somewhere around abouts the wee round silver capsule type thing on top of the fuel rail. the fuel is comming from either the capsule thing (what is it?) or the pipes going into it, has anyone come across this before? is tightening the pipes somehow the cure?
Was the any kind of recall for this stuff?
Thanks people.
petrol leak drip drip drip
Re: petrol leak drip drip drip
You'll probably find that the hose is split.philg wrote:only seems to happen if i'm gunning the engine. i get a seriously strong wiff of petroleum from my 1998 2.0L16v 136bhp. i open the bonnet and theres fuel dripping from somewhere around abouts the wee round silver capsule type thing on top of the fuel rail. the fuel is comming from either the capsule thing (what is it?) or the pipes going into it, has anyone come across this before? is tightening the pipes somehow the cure?
Thanks people.
I have a 1996 version of what you've got and I had a leak too.
It was the hose that feeds the rail. (come from the bulkhead, sits on top of the cylinder head in a plastic shroud then into the fuel rail.
Mine split just as it attaches to the rail.
I got a replacement from the dealer for £35 and found that that exact section of the pipe was re-enforced! Peugeot must have found out it breaks after a certain time period.
Was easy to replace. 5 minutes and 2 jubilee clips.
- 1.6 8v
hey guys,
i'm new here cuz i just bought a 1996 406 2liter. Same problem with the fuel leakage, and I can see it dripping too. I am guessing that I can just replace the tubes with these right?:
http://cgi.ebay.co.uk/6mm-1-4-OVERBRAID ... dZViewItem
or will i have to actually get it from pug dealership?
- jameslxdt
same here, mine actually decided to split during the mot
, there was a recall on this when it first came out but some cars missed it, there was also a modified fuel filter (plastic instead of metal) that was fitted at the same time
