MOT failed need part advice
sturose
Post by sturose »
Hi, just took a 406 hdi for mot and it failed on a rear suspension upper ball joint. Searching for the part to replace is proving difficult!
I can find many front lower ball joints but nothing for rear upper.
Can anyone advise what this part might be? I've been asked to obtain the part so a local garage can fit it for me but I've no idea what I'm looking for.
Cheers guys.
Re: MOT failed need part advice
Upper ball joint? There are bushes but no ball joints, unless it's the anti roll bar link, or there's one in the end of the track arm :?
sturose
Post by sturose »
Strange, it actually states on the mot refusal,
"suspension arm ball joint excessively worn offside rear upper"
Any ideas or should I contact the mot station to clarify?
dirtydirtydiesel
Post by dirtydirtydiesel »
It'll be the one for adjusting the rear tow,
I got mine from Eurocarparts, but carparts4less are there sister company & cheeper
The part is know as suspension arm rear, it has a ball joint one end & a bolted joint the other
where the offset bolt goes.
It's advisable to source new adjustment bolts, offset washers & nuts before doing the job
& you'll definitely need a rear suspension alignment after (mine was dangerous)
& yes I'd marked it up.
If you have a look through my post's, I'd put picture's up.
Sorry just looked & pic's have vanished.
dirtydirtydiesel
steve_earwig wrote: Tue Oct 13, 2020 6:27 pm Upper ball joint? There are bushes but no ball joints, unless it's the anti roll bar link, or there's one in the end of the track arm :? mecapassion_1142086018_suspension.jpg
Part no 13 gents, have a good looky Steve
You'll see a ball joint at the hub end :wink:
Toe arm, track arm, link arm, I dunno what it's called but I wouldn't have said upper ball joint :?
Wasn't there some issue with obtaining the adjustment gubbins?
sturose
Post by sturose »
dirtydirtydiesel wrote: Tue Oct 13, 2020 8:53 pm It'll be the one for adjusting the rear tow,
Well that makes it a bit clearer than what the mot station have put on the refusal. Still not 100% sure which part is actually needed because searching for suspension arm rear still gives a few different items.
Think I'll have to contact them for clarification, you would think the "professionals" would put correct details on the notes. Literally nobody online, either ebay or other online stores even mentions ball joints for that area!
Thanks for the help.
sturose
Post by sturose »
Is this the part you are referring to?
https://www.carparts4less.co.uk/p/ocap- ... -600735208
Never mind, been back to the garage and confirmed, this is the part. Why they have put it down as a ball joint is beyond me!! Every place online calls it a suspension link bar or anti roll bar link. I would have had a clue if they put that on the mot!
Decision time though, do I pay my local garage to fit or roll my sleeves up and get dirty this weekend 😂
This bar and front discs and pads to do!
The antirollbar link is plastc (I think) and has a balljoint each end, we can't look up the parts diagrams any more so I can't tell you the proper name for the other link but it controls track (& trace?) and camber. A quick search later... yeah, there are loads of sites listing it as the antirollbar link. Horizontal link rod? That sounds better.
There is a ball joint one end of it but calling it "upper" rather implies there's a lower, and there aint.
And the lesson is: Always get the tester to show you the part 'cos a lot of the time he might be calling it the wrong name.
dirtydirtydiesel
steve_earwig wrote: Wed Oct 14, 2020 5:24 pm The antirollbar link is plastc (I think) and has a balljoint each end, we can't look up the parts diagrams any more so I can't tell you the proper name for the other link but it controls track (& trace?) and camber. A quick search later... yeah, there are loads of sites listing it as the antirollbar link. Horizontal link rod? That sounds better.
Steve, my tester mark's the failed part's with a yellow paint pen.
dirtydirtydiesel
[/quote]
Yes, Peugeot main stealers got them back in though, but that was a few years back
They are available on fleabay :wink:
dirtydirtydiesel
sturose wrote: Wed Oct 14, 2020 1:48 pm Is this the part you are referring to?
Look up, I did say no 13 in the diagram that Steve posted up.
dirtydirtydiesel
Don't forget what I said about the elliptical washers & bolts, you will need them (trust me)
Yeah, it's straight forward enough, but you will need to get proper rear wheel alignment done after.
dirtydirtydiesel wrote: Wed Oct 14, 2020 6:43 pm Steve, my tester mark's the failed part's with a yellow paint pen.
That sounds like a great idea, unless it's a part you can only see with the car up on a lift... :supafrisk:
sturose
Post by sturose »
dirtydirtydiesel wrote: Wed Oct 14, 2020 6:47 pm
Yeah I noticed it was the same part.
dirtydirtydiesel wrote: Wed Oct 14, 2020 6:50 pm Don't forget what I said about the elliptical washers & bolts, you will need them (trust me)
Elliptical washers and bolts? Any idea of sizes, quantities etc?
